Activity Forums Adobe Premiere Pro Change to color inverted
  • Change to color inverted
    Posted by Kent Wallis on December 22, 2013 at 5:30 am
    This driving me nuts. I’ve rotoscoped a person to place on a different background but the original background shows through under their arm off and on. The original background was a solid color so I thought I could save some time and just use “change to color” in Premiere Pro CC to change it to green and key it out in After Effects. For some reason it is changing everything but the color I choose as “From”. I tried it in After Effects with the same result.
    Any ideas on why, how to fix and or a better way to handle the problem. It’s a very small area that rotobrush doesn’t handle well. I used a photoshop batch action to fill a similar area in an image sequence but this spot moves around.
    Kent Wallis replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
