Activity › Forums › Adobe After Effects › Change to B&W
Change to B&W
Posted by Wasteland on August 17, 2005 at 5:58 pmwhats the plugin to change your video to B&W and leave one color like red or something
Mark replied 21 years, 1 month ago 4 Members · 4 Replies -
Stewart Boyles
August 17, 2005 at 6:08 pmI don’t know of a plugin that will create a mask that will track to video.
I wanted to create this same effect and I had to mask the specfic piece frame by frame. It turned out Ok but I would love a plugin that would do this…
Stewart
Wasteland
August 17, 2005 at 7:35 pmthere is a plugin, replace color or something I have used before you just use an eye dropper to pick your color and the rest goes black and white.
Helgi Johannsson
August 17, 2005 at 8:23 pmGo to Effects > Stylize > Leave Color
You can also use Image Control > Colorama.
Mark
August 18, 2005 at 12:32 pmI prefer to use “Change color” This filter has the option to create a matte…I can then use this matte as a track matte for the layer that I want to leave the color on, then I can add a third layer under it all and colorize it, or effect it in any way I want to independantly of the other layers.
Mark
