Activity Forums Adobe Audition Change timing and syncing video/audio
  • Change timing and syncing video/audio
    Posted by Randall League on February 16, 2010 at 3:29 pm
    Hello all, was wondering i someone could help me.
    I have a video file which has an American speaking good japanese, the video file is actually part of a lower third of a bigger composite. While the japanese the American speaks is good it is a little slow and slightly hesitant, I found that if I take the file in Soundbooth and increase the timing (around 91%-94%)and lower the pitch it makes his japanese sound much smoother, but of course the problem is that its not only audio but a video file and once I change the timing for the audio file the syncing of the mouth and words are all screwed up. Not by a lot to be honest since the files are only 20-30 seconds each. I was wondering the best way to sync these back up? Do I have to mess with Time-remapping in After Effects?Is there a better way to do this?
    Rob Neidig replied 16 years, 7 months ago 2 Members · 1 Reply
  • Rob Neidig
    February 16, 2010 at 9:39 pm
    Randall,
    The “time remap” in After Effects should work. You didn’t mention what video editing software you use, but many packages offer a “speed” or “time remap” effect in the software. Usually you apply it to both video and audio at the same time, so it automatically stays in sync.
    Have fun!
    Rob
    Rob Neidig
    R&R Media Productions
    Eugene, Oregon
