Activity › Forums › Adobe After Effects › Change timeframes to seconds?
  • Change timeframes to seconds?
    Posted by Sara Stifler on November 8, 2014 at 10:31 pm
    So I know many of you can go to File > Project Settings and select Timecode to display seconds instead of timeframes, and I know you can Cmnd+click over the timecode in the corner, but it doesn’t work for me and I’m not sure why.
    When I toggle between display units, it simply switches between 00:00f and 0000 formats – it never goes to seconds.
    Any idea why that is?
    John Cuevas replied 11 years, 10 months ago 2 Members · 3 Replies
  • John Cuevas
    November 9, 2014 at 12:35 am
    Because timecode isn’t measure like that, it’s measured either in total frame count or hours:minutes:seconds:frames.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Sara Stifler
    November 9, 2014 at 1:25 am
    But in some people’s interface you see the timecode displayed in seconds. How can I configure mine to also use seconds?
  • John Cuevas
    November 9, 2014 at 1:21 pm
    The timecode 00:00f would be your seconds:frames timecode. Though I’m not sure how you are getting the “f”, can you post a screen grab of your timeline.
    Thinkck.com
