Activity › Forums › Adobe After Effects › Change time speed.. for a whole precomp, that uses write-on effect to reveal image
  • Change time speed.. for a whole precomp, that uses write-on effect to reveal image
    Posted by Paul Boone on February 2, 2012 at 7:41 pm
    ok, so I have a black border of a bed that is being drawn on by means of the write-on effect using reveal image. I have arranged the keyframes so that the bed is drawn on smoothly and at the same speed. I assumed that if I got the lines drawn in at an even speed, I could precomp it, and then add something like timewarp to tweak the speed of the whole pre-comp, rather than adjusting each individual keyframe of which there are about 15. When timewarp is applied, the bed is no longer drawn in and is just a still image. perhaps another time adjustment effect?
    What’s the best way to do this? I guess I could render it out and import it back in, but I would like the freedom to adjust certain things.
    There are many layers that have different images, so I thought it was worthwhile to find a better way to adjust speed of a whole precomp than exporting and importing back in.
    Paul Boone replied 14 years, 8 months ago 2 Members · 2 Replies
  • Ben G unguren
    February 2, 2012 at 10:00 pm
    Make sure all the animating stuff is in the precomp. Then it should work simply by enabling time remapping (command+opt+T) for your layer. Just tweak your start and end keyframe and you’re set.
    Using Timewarp for remapping is mostly used with original footage, to add motion blur or introduce tween frames. If you have a precomped animation, and you time remap it, AE will automatically interpolate additional values for you so the write-on effect should move smoothly.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Paul Boone
    February 3, 2012 at 1:46 am
    Nice. This is exactly what I was looking for. Thanks Ben
