Activity Forums Adobe After Effects Expressions Change the value only for the second keyframe in a position aplication
  • Change the value only for the second keyframe in a position aplication
    Posted by Sorin Gabriel on January 28, 2021 at 3:54 pm
    Hello all! I’m so glad that i made this step and joined this amazing community!
    I have a small problem, this worked out in the past for only one parameter (scale, opacity, rotation), but now i need for position, and get the error that i need it to be in 2 dimensions not one.
    So, to be more precisely, i want to keep my animation and change only the second keyframe that should contain x,y coordinates with slider controls, i need this for and essential graphics template.
    Hope that someone will understand what i want if not i can post more pictures.
    This line i want to make it dynamic so the user can choose where to point it and also keep it’s animation
    Kevin Camp replied 5 years, 7 months ago 2 Members · 4 Replies
  • Sorin Gabriel
    January 29, 2021 at 2:03 pm
    anyone? 🙁 i really need this done, thank you again!
  • Kevin Camp
    January 29, 2021 at 4:35 pm
    it looks like you have two slider controls, I’ll assume you want one to control the x-position and the other to control the y-position of one end of the beam effect.
    If so, then try something like this on the beam point you want to affect:
    x = effect("Slider Control 1")("Slider") ; // point this at one slider
    y = effect("Slider Control 2")("Slider") ; // point this at the other
    [ x, y ]
    Alternatively you may be able to use a Point Control that natively has 2 dimensions. Then the expression would simply be this:
    effect("Point Control")("Point")
  • Sorin Gabriel
    January 29, 2021 at 5:47 pm
    Thank you Kevin! But I know this, i want to modify x an y correctly with a slider control, but as an addition I want the second key frame to have the new x,y values, anywhere i change the x,y values on the timeline… And not generate a third key frame.
  • Kevin Camp
    January 29, 2021 at 10:03 pm
    If you use a Point Control on the same layer that the beam effect is on and the ease on the keyframes is the standard easy-ease, this should work:
    p1 = key(1).value ;
    p2 = effect(“Point Control”)(“Point”) ; // pickwhip to your point control
    ease(time, key(1).time, key(2).time, p1, p2 )
    If you need to use sliders, then this should work:
    p1 = key(1).value ;
    x2 = effect(“Slider Control 1”)(“Slider”) ; // pickwhip to your x-position slider
    y2 = effect(“Slider Control 2”)(“Slider”) ; // pickwhip to your y-position slider
    p2 = [ x2, y2 ] ;
    If the ease on the keyframes is using a custom velocity then it will get a more complicated.
