Activity › Forums › Apple Motion › Change the name in the Behaviors.
  • Change the name in the Behaviors.
    Posted by Terry Maloney on August 23, 2017 at 1:08 pm
    Hi, ????
    I am making many audio behaviors on one JPG over time. Their names are defaulted as Audio, Audio 1; Audio 2 etc.
    I need to make these names more descriptive. I can’t use the source material because they have their own descriptive names.
    Thank you,
    Terry
    Simon Ubsdell replied 9 years, 1 month ago 3 Members · 4 Replies
  • Mark Spencer
    August 23, 2017 at 1:25 pm
    You can rename any behavior (or any filter or mask or layer or group) to anything you want. Just double-click the name in the Layers list.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Terry Maloney
    August 23, 2017 at 1:49 pm
    Hi Mark, ????
    There are no behaviors in the layers list. I go to properties of the picture and add a audio parameter there. Then the Behaviors window automatically opens up and I make my adjustments there.
    If I add a move behavior to the project the other way, I don’t know how to make it controlled by audio. It’s all key frames then.
    Terry
  • Mark Spencer
    August 23, 2017 at 2:07 pm
    If the behavior isn’t appearing below the layer you have it applied to in the layers list, then you have disabled the view of behaviors – small icon at the bottom of the layers list.
    Mark Spencer
  • Simon Ubsdell
    August 23, 2017 at 2:10 pm
    [Terry Maloney] “There are no behaviors in the layers list.”
    That’s because you have disabled the Show Behaviors button at the bottom of the Layers panel:
    Turn it back on to see your behaviors in the Layers Panel where you will be able to rename them.
    Simon Ubsdell
    tokyo productions
    hawaiki
