Activity › Forums › Boris FX › Change the location of moving object in Mocha pro
  • Change the location of moving object in Mocha pro
    Posted by Hyein Lee on January 27, 2019 at 12:33 pm
    I’d like to take a video of motorcycle running on the road. And actually make it to look like it’s running towards the sky. Can I do this with mocha pro ? If i can, how can I do this?
    Thanks.
    Mary Poplin replied 7 years, 8 months ago 2 Members · 1 Reply
  • Mary Poplin
    January 28, 2019 at 7:11 pm
    To do this, I would use Mocha Pro’s remove module to remove the motorcycle and rider from the shot and then use Mocha roto to composite the rider back over the scene and then manually animate the rider off into the sky. It is a tricky shot and will depend on how you shot it in order to achieve this well.
    I’d need more information to be more specific.
    Cheers,
    Mary
    Mary Poplin
    Product Specialist
    maryp@imagineersystems.com
