Activity › Forums › Adobe After Effects › Change the dpi for image renders
  • Dale Hayward
    March 24, 2009 at 3:02 pm
    thanks dave! i knew that AE doesnt really care about the dpi, but i was trying to re-render a sequence of images that i applied some effects to, but as images, & since AE defaults the images at 72 dpi, they look like poo. any suggestions on a way around that?
    d-ale
    blog: https://ostrichindustries.blogspot.com/
  • Brian Cahill
    March 13, 2010 at 1:04 am
    If you save as a .TIFF file it saves as 96 dpi
  • Chris Mccorkel
    March 10, 2016 at 2:35 am
    Hope I’m not bringing this from the dead! I’m not a forum user per say…
    If I understand you correctly, you need to keep your image sequence at 200 dpi when exporting from after effects. I don’t know the size of your canvas but I will give an example. I make my business cards (3.5×2 inches) in after effects and say I wanted mine exported at 200 dpi as a jpg. This would mean I would have to set my composition up with pixel ratio of 700×400, BUT I’m still not finished as I’m using AE!! Now you have to import this into a photoshop canvas (3.5×2 inches) and scale to fit if some magical way it doesn’t do it by default. Hope this helps if anyone ever sees this lol.
    Chris McCorkel
    Atlanta CW – Shooter – Editor – Sum GFX
