Activity Forums Adobe Premiere Pro Change the codec for a multicam project
  • Change the codec for a multicam project
    Posted by Mike Tomei on September 20, 2011 at 1:29 am
    Hello everyone,
    I have a situation I’m hoping you all can help with. I have AVC-INTRA 100 720p60 footage from three cameras recorded on P2 cards that I mistakenly placed in a DVCPROHD 720p60 sequence. I then nested that sequence inside another DVCPROHD 720p60 sequence so I could multicam edit all the cameras. After I finished the project, I had that “duh” moment when I realized that it was actually AVC-INTRA 100 footage, and not DVCPROHD footage. Now I’m wondering how to change both sequences to the correct codec.
    So I know that I can simply create a new AVC-INTRA 100 sequence, copy all the contents of sequence 2 (my multicam enabled sequence with all the edits) and paste it in the new AVC-INTRA 100 sequence. The issue I’m having is that since it contains a nested sequence for the multicam edit, and the nest is pointing to the original sequence with the footage from the three cameras that’s still incorrectly in a DVCPROHD sequence. So I’m wondering how to get the codec changed to AVC-INTRA 100 for the sequence with the footage from the three cameras, then tell the nested sequence to now point to the correct location?
    Jeez, I hope I explained that clearly! As always, thanks in advance for the help.
    Mike Tomei
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    500GB system HD, 4x1TB RAID5 media array
    Adobe Production Premium CS5
    https://blog.miketomei.com
    Mike Tomei replied 15 years ago 2 Members · 4 Replies
  • Todd Kopriva
    September 20, 2011 at 4:49 am
    It looks like you got an answer here.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Mike Tomei
    September 20, 2011 at 1:27 pm
    Hi Todd,
    You’re right, Colin Brougham bailed me out once again and came through with a great solution to my problem. Worked like a charm.
    Todd, on a side note, I enjoyed your “Optimizing Performance for Adobe Production Premium” class at NAB’s Post Production World last April.
    Take care.
    Mike Tomei
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
  • Todd Kopriva
    September 20, 2011 at 1:30 pm
    Thanks. Glad you liked it.
    There’s an extended and polished version linked to from here.
  • Mike Tomei
    September 20, 2011 at 2:26 pm
    Hi Todd,
    Looks like a great resource. Thanks for the link.
    Mike
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
