Activity Forums Maxon Cinema 4D Change texture on during animatio
  • Adam Trachtenberg
    December 14, 2009 at 4:31 pm
    Looks like the texture change is animated along a sweep nurbs (in Cinema parlance). What I would do in this case is give the object two materials (two texture tags). The first material is represented by the texture tag to the right of the other texture tag. The second material would have an animated gradient in the alpha channel that would reveal the underlying material when animated.
