Activity › Forums › Adobe After Effects Expressions › Change text properties using ExtendScript
  • Change text properties using ExtendScript
    Posted by George Beridze on January 16, 2024 at 2:22 am
    Hey guys,
    I know this is an expressions forum category and I have a question about Extendscript, but maybe I can still post about it?
    So, I’m trying to change one of the text properties here.
    I can successfully change Anchor Point Grouping (see here), using the code below:
    var thisComp = app.project.activeItem;
    var curLayer = thisComp.selectedLayers[0];
    textAnchorPointGrouping = curLayer.property("Text").property("More Options").property("Anchor Point Grouping");
    textAnchorPointGrouping.setValue(1);
    But, when I want to change Based On (see here) property under Range Selector, it’s not working and i’m getting undefined is not an object error (see here). Below is the code:
    textAnchorPointGrouping = curLayer.property("Text").property("Animator 1").property("Range Selector 1").property("Advanced").property("Based On");
    Not sure what I’m doing wrong and any suggestions would be helpful!
    Brie Clayton replied 2 years, 8 months ago 3 Members · 6 Replies
  • Dan Ebberts
    January 16, 2024 at 3:27 am
    Try changing the 3rd line to this:
    textAnchorPointGrouping = curLayer.property("Text").property("Animators").property("Animator 1").property("Selectors").property("Range Selector 1").property("Advanced").property("Based On");
  • George Beridze
    January 16, 2024 at 3:46 am
    Legend!
    Works perfectly – You just saved me a lot of hours of manual work.
    One more question, please:
    If I have several layers selected (layers are duplicates of each other, each one has the same exact names on text animators), the code doesn’t work on all selected layers – it only works on the first selected layer, not the rest.
    How would I fix that?
  • Dan Ebberts
    January 16, 2024 at 4:44 am
    Try it this way:
    var selectedLayers = thisComp.selectedLayers;
    for (var i = 0; i < selectedLayers.length; i++){
    textAnchorPointGrouping = selectedLayers[i].property("Text").property("Animators").property("Animator 1").property("Selectors").property("Range Selector 1").property("Advanced").property("Based On");
  • George Beridze
    January 16, 2024 at 5:25 am
    Here I’m getting “null is not an object” error on textAnchorPointGrouping, here’s what’s happening
  • Dan Ebberts
    January 16, 2024 at 7:44 am
    My guess would be that one of your selected layers doesn’t have the same Animator setup as the others, so that the property spec selectedLayers[i].property(“Text”).property(“Animators”)…. doesn’t actually exist.
  • Brie Clayton
    January 16, 2024 at 2:31 pm
    Thank you for solving this, Dan!
