Activity › Forums › Adobe After Effects Expressions › Change text color every word
Posted by David Schagerström on October 9, 2014 at 9:01 amHi!
I’m working on some text and this seems fairly easy, but havnt found a way of doing it yet. My text needs to change color every new word. Its goes between 3 colors. So its “Red blue green red blue green red blue”. It shouldnt animate. Any ideas?
Trevor Asquerthian replied 11 years, 10 months ago 3 Members · 8 Replies -
David Schagerström
October 15, 2014 at 8:28 amSome stuff has changed. It now needs to change between 3 color like this 1 2 3 2 1 2 3 2 1.
What I’ve tried to do is to I’ve set the text color to color 1. Then added two fill color expressions. the first one has …textIndex%3 ? 0 : 100
and the secondtextIndex%2 ? 0 : 50
But it gets messy after the first 3 word as one would expect. was thinking that I could get solved with an “if” expression, but have no idea how to write it.Thanks for any help!
Dan Ebberts
October 15, 2014 at 1:36 pmI would think one would be like this:
(textIndex-1)%4 == 1 || (textIndex-1)%4 == 3 ? 100 : 0
and the other would be like this:
(textIndex-1)%4 == 2 ? 100 : 0
Dan
Trevor Asquerthian
October 15, 2014 at 2:33 pmI managed this by butchering one of Dan’s other posts:
Set text colour to white
Add animator for fill colour RGB – set that colour to black
Add text selector | expression – set amount to 50%,50%,50%then in that amount add the following expression:
palette = [[0,100,100],[100,0,100],[100,100,0],[0,0,0]];
// [red,blue,green,white]switch (textIndex%4) {
case 1:
idx = 0;
break;case 3:
idx = 2;
break;default:
idx = 1;
palette[idx]
David Schagerström
October 15, 2014 at 3:08 pmCheers Dan! Works like a charm!
Question, I need to make this a color. This only allows me to change the grey scale. how would i change it to RGB?Thanks!
David Schagerström
October 15, 2014 at 3:27 pmThanks trevor! It seems to work. I just dont understand the color values? are they in RGB? cant change them into what I need.
Cheers!
Dan Ebberts
October 15, 2014 at 3:56 pmThis is for a Fill color animator with an expression selector, correct? One of the choices is RGB. Or maybe I don’t understand what you’re doing.
Dan
David Schagerström
October 15, 2014 at 4:01 pmOk I understand now how it works! I was being slow.
Thanks again! -
Trevor Asquerthian
October 16, 2014 at 6:17 pmI’ve kind of figured out what is going on… 😉
Adding the fill (RGB) animator allows the change of levels between the ‘text’ colour and the ‘fill’ colour
The ‘range selector’ doesn’t allow for a per word selection, only a range within the whole text box, so we delete that
The ‘expression selector’ allows the change to occur based on the index of text within the text box – with the expression disabled you can see the colours generated by using the ‘amount’ values as R G and B. – i.e. at 100,100,100 it is all ‘fill’ at 0,0,0 it is all ‘text’ colour
It’s less confusing if the text colour is Black and the Fill is white – thus the amount values become RGB rather than 1-R, 1-G, 1-B.
With the amount expression enabled the default expression does a gradation between black and white over the text box.
With the expression below the value depends on the index of the word (if ‘words’ is selected for the expression to be based on)
The palette can be changed accordingly
I hope this helps, it certainly helped me to think about it (and thanks to Dan for the original)
palette = [[100,0,0],[0,100,0],[0,0,100],[100,100,100]];
case 1:
idx = 0;
break;case 3:
idx = 2;
break;default:
idx = 1;
palette[idx]
