Activity › Forums › Adobe Photoshop › change text box size without changing text proportions size etc
  • change text box size without changing text proportions size etc
    Posted by Adam Chesbrough on December 15, 2011 at 7:42 pm
    When ever I change the size of a text box within PS CS5 the proportions of the text change with it. I want the text size and proportions to remain the same but just alter the size and location of the box. I imagine it works will dragging while holding a combination of cmd, alt, cntrl, shift but no of them seem to work…THanks
    macbook pro 17″ i7, 8GB RAM
    2 RAID 0 esata external HD 7200RPM
    Scott Roberts replied 14 years, 8 months ago 3 Members · 2 Replies
  • Sanjeev Ramanathan
    December 26, 2011 at 4:10 pm
    Select the text by double clicking on the text or ‘Ctrl A’, you should get a black highlighter of the text.
    Hold the ‘Ctrl’ and you should get a trasformation box around the text, if you click on the corner you will change its proportion. whereas if you click inside the text (Anywhere but center of the text, that will move the alignment) you will move the placement.
    Beekeeper
    https://www.beekeepersblog.com
  • Scott Roberts
    January 2, 2012 at 4:30 am
    Use the text tool and click on the text, as if you’d be typing/editing the text, then simply drag the handles for the text box.
    LittleBlackBird.net
    My Blog
