Activity Forums Adobe After Effects Expressions Change text based on Color Map
  • Change text based on Color Map
    Posted by Liam Campbell on January 17, 2017 at 1:35 am
    I’m looking to make a block of text but in a “paint-by-numbers” sense I want to use a map and make the darkest values be a “$” for example and the lightest values to be a “/” for example. Similar to the images/emojis created from keyboard characters. But I basically want to be able to create an animated black and white map that would be made out of different characters rather than values.
    Emre Anil replied 9 years, 8 months ago 2 Members · 1 Reply
  • Emre Anil
    January 17, 2017 at 1:44 pm
    So basically you’re looking for a frame by frame ASCII converter in After Effects..
    Found this one for you: L3tt3rm4pp3r
