Activity › Forums › Adobe After Effects › Change Stroke on 3D Text
  • Change Stroke on 3D Text
    Posted by Devon Farrell on June 18, 2012 at 2:15 pm
    I have ray traced 3D white text, how do you change the excursion color? With a 3D shape I change the stroke color. But when I change the stroke of the text it doesn’t change the color.
    Roland R. kahlenberg replied 14 years, 3 months ago 2 Members · 5 Replies
  • Roland R. kahlenberg
    June 18, 2012 at 3:10 pm
    Your stroke color should appear, again, once you set your Bevel Style to something other than None, with a Bevel Depth > 0.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Devon Farrell
    June 18, 2012 at 3:18 pm
    My bevel depth is greater than zero here a pic.
    https://www.redcmedia.net/images/screen_shot.png
    June 18, 2012 at 3:31 pm
    BUT your Bevel Style is set to NONE. Change it from this default, as I had suggested in my earlier post.
    Cheers
    RoRK
  • Devon Farrell
    June 18, 2012 at 5:19 pm
    Ok set my Bevel Style to concave and this is the problem I’m running into
    https://www.redcmedia.net/images/screen2.jpg
    Thanks for the help. It’s appreciated.
    June 18, 2012 at 5:50 pm
    All I can tell from the image is that the text doesn’t look good. You’ll of course have to finesse the settings to get it to look good. Other than that, do you have any specific issues/questions.
    Cheers
    RoRK
