Activity Forums Adobe Illustrator Change stoke or fill simultaneously
  • Change stoke or fill simultaneously
    Posted by Andy Baumgartner on September 14, 2016 at 10:56 pm
    Hi, does anyone know of a way to change the stroke and fill simultaneously, depending on whether a stroke or fill exists?
    For example, I have a graphic with a type label, and an arrow coming out. The type has a fill, the arrow has a stroke. I would like to change the color of both simultaneously, without adding a stroke or fill where one did not exists before.
    I am aware I could expand, outline, etc. but I need to be able to retain the elements edit-ability.
    -Andy
    Kalleheikki Kannisto replied 10 years ago 3 Members · 2 Replies
  • Vincent Rosati
    September 14, 2016 at 11:13 pm
    I can’t think of a solution that meets that exact requirement, to do two appearances in one command.
    Though a Graphic Style can apply a fill, stroke, and other effects in one operation, but it sounds like you would need 2 Graphic Styles.
    Create an object with the desired attributes, then drag it into the Graphic Styles palette, and name it.
    Are you familiar with the Select > Same… commands? They might be useful.
    • Select same fill color
    • Select same stroke color
    • Select same stroke weight
    • etc..
    Then possibly follow by using one of your custom Graphic Styles.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
  • Kalleheikki Kannisto
    September 15, 2016 at 6:31 am
    If you make the color a custom color, you can change it in the color palette.
    Senior Graphic Designer
