Activity › Forums › VEGAS Pro › change still image length in DVDA 3.0c
  • change still image length in DVDA 3.0c
    Posted by Mike Kujbida on December 13, 2005 at 5:45 pm
    One of the menu items for a DVD I’m working on brings up a still that describes the contents of the Extras folder.
    I’m sure it can be done but I don’t see any way to keep it on screen for longer than 5 seconds.
    Any suggestions? Thanks.
    Mike Kujbida replied 20 years, 9 months ago 3 Members · 5 Replies
  • Gary Kleiner
    December 13, 2005 at 7:21 pm
    Not sure of your approach, but to change the menu page duration:
    Menu Page Properties>Menu Length>Specify
    Length>0:00:00:00
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Mike Kujbida
    December 13, 2005 at 7:56 pm
    Thanks Gary but that doesn’t do it.
    I’ll see if I can make myself clearer.
    I have 6 separate menu items.
    #6 is titled “DVD Extras” and, when clicked, links to a still image that has a list of the contents of this folder. It only stays up for 5 seconds though and then goes back to the main menu. I’d like it to stay up for 15 seconds if at all possible.
  • Gary Kleiner
    December 13, 2005 at 8:35 pm
    OK, I see what you’re doing.
    Interesting question as I don’t know of an easy way to adjust the length of playback when you point to an image file.
    The best bet for you is to create a picture compliation of one image (you can adjust the duration there) and point to that instead.
    Gary Kleiner
  • Edward Troxel
    December 13, 2005 at 8:36 pm
    Instead of linking to a picture, link to a SUB MENU and make the picture the background image. By default, it will have a “return” button to go back to the main menu.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    December 13, 2005 at 10:26 pm
    Thank you VERY much (once again) Edward.
    Your Submenu trick worked perfectly.
    I can now go home a happy (and stress-free) man 🙂
    Mike
