Activity Forums Boris FX Change speed of title crawl
  • Change speed of title crawl
    Posted by Eric Holzapfel on October 4, 2009 at 3:08 am
    Hello All,
    I am using Boris FX title crawl in FCP 6.
    I have yet to find a way to control the speed of the crawl.
    I am using the percent complete to step things up, but it is
    not too elegant.
    Is there some way to slow the roll speed down from 100 to like 85??
    Eric
    Matt Mullen replied 16 years, 11 months ago 2 Members · 1 Reply
  • Matt Mullen
    October 5, 2009 at 2:17 pm
    Eric,
    The easiest way to do this is to create the title using the generator.
    Create the title crawl. Once your back in the FCP interface if you do not like the desired length you can grab and shorten the generator clip right in the timeline. Re-render and you should see the desired effect.
    If you know the length before creating the title set the generator clip to that length before creating the crawl.
    Let me know if this helps.
