Activity Forums Adobe Premiere Pro Change size picture alpha channel
  • Change size picture alpha channel
    Posted by Max Mustermann on August 25, 2022 at 1:19 pm
    Hello. How can i change the size of this alpha channel picture? The text size over it is changeable, but that alpha channel canvas is not. I looked at all the Settings and cant find the solution to change the size. When i click “Set to 100%” nothing changes, there are no scalable frames to change the size, in the Effects Settings only the text size changes. Thx
    Max Mustermann replied 4 years ago 2 Members · 2 Replies
  • Eric Santiago
    August 26, 2022 at 1:51 pm
    If that’s a timeline then maybe set it to a higher resolution.
  • Max Mustermann
    August 29, 2022 at 5:31 pm
    i have found that out. The text had “cropped”effect below in the effects list options, so i thought that was something wrong with the canvas. Thx
