Activity › Forums › Apple Motion › Change Single Z-location on shape
  • Change Single Z-location on shape
    Posted by Ralph Johnson on February 12, 2010 at 6:11 pm
    Is it possible in MOTION to move the z-location of just one point on a square created with the rectangle tool (i.e., without moving the remaining points on the square. Thanks.
    Mark Spencer replied 16 years, 7 months ago 2 Members · 8 Replies
  • 8 Replies
  • Mark Spencer
    February 12, 2010 at 6:13 pm
    Shape control points only include x and y as you can see in the Inspector – they are always flat planes (that you can rotate in 3D space)
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Ralph Johnson
    February 12, 2010 at 6:18 pm
    What if I create the square using the B-Spline or Bezier tool. It is then possible to move a single point on the construct in the z-dimension without disturbing the others points on the construct? Thanks for the earlier response. I could see in the inspector that only two dimensions could be altered, but hope there was a work-around. I appreciate your advice.
  • Mark Spencer
    February 12, 2010 at 6:20 pm
    The workaround is to not use a shape, which is always a 2D plane. You can use a replicator or an emitter on a motion path – the control points of a motion path have x, y, and z.
    Mark Spencer
  • Ralph Johnson
    February 12, 2010 at 6:21 pm
    Got it. Thanks!
  • Ralph Johnson
    February 12, 2010 at 6:35 pm
    It seemed so simple reading your words on the post, but I can’t make it happen. Could you just give me a quick outline as to how to create a square using a motion path? Thank you so very much.
  • Mark Spencer
    February 12, 2010 at 6:37 pm
    You have to draw it by hand by double-clicking on the path to add control points and moving them….
    Mark Spencer
  • Ralph Johnson
    February 12, 2010 at 7:54 pm
    How do I get something (anything) on the motion path? Sorry. Thanks for your patience and very helpful information.
  • Mark Spencer
    February 12, 2010 at 8:11 pm
    One way is to replicate a small circle and use the motion path as the shape source for the replicator.
    Mark Spencer
