Activity › Forums › DSLR Video › Change shutter speed in Canon 7D
  • Change shutter speed in Canon 7D
    Posted by Vladimir Lozinski on April 2, 2010 at 2:13 pm
    Hi.
    Thanks for setting up this forum as it has been a wealth of knowledge so far.
    I have my new Canon 7D. AM shooting in 25p and cannot find how to change the shutter speed to 25 or 50 FPS. All options come up as 30, 45, 60,90 etc.
    Also cannot access the screen menu to set up my custom controls to set the aperture and shutter settings.
    V.L.
    Ronny Ronster replied 11 years, 9 months ago 10 Members · 15 Replies
  • 15 Replies
  • Neil Abeynayake
    April 2, 2010 at 6:55 pm
    Vladimir,
    Your camera came with an instruction manual and it helps to read it once in a while. In case you have misplaced it, here is a link from Canon Digital Learning Center which might help you.
    https://cdn.sellpoint.net/canon/EOS_7D-11_Movie_Mode_Basics.html
    Good luck,
    Neil
    “Always remember that you’re unique. Just like everyone else”.
    Confucius
  • Vladimir Lozinski
    April 2, 2010 at 7:31 pm
    Thanks for the sympathetic note but the menu is not the issue.
    Outside America people like to shoot in 25 PAL ( Pictures At Last) and shutter speeds as a multiple of that are preferable. It usually helps with lighting flicker which runs at 50hz etc. I cannot find any reference in the manual to adjusting shutter speeds to 25, 50, 100 etc.
    Thanks.
    V.L.
  • Vladimir Lozinski
    April 2, 2010 at 9:09 pm
    Thanks for the humane response.
    I understand shooting formats and have no problem with the shooting frame rates.
    I have worked in PAL, NTSC and now HD for the US networks in Europe and Middle East and Asia for the past 30 years as a vid-kid and beyond, but am new to DSLRs
    My specific question is the shutter speed. For some reason I cannot dial up a shutter of 25, 50, etc. I only have the 30, 60, etc. options.
    The camera came from the US where multiple of 30 shutter speeds are not an issue. I just feel more comfortable operating in 25 FPS with a 50, 100 frame shutter rather than 30 or 60.
    Cheers.
    V.L.
  • Norman Pogson
    April 2, 2010 at 9:46 pm
    Are you in Tv or Av mode?
    Double check you are in manual mode, select movie shooting at the start/stop button, rotate the wheel on the top plate near the shutter and you should see 40 50 60 etc. You will not see less than 1/30th in movie mode.
    My Canon 7D Blog
  • Vladimir Lozinski
    April 2, 2010 at 10:16 pm
    HI.Thanks for the response.
    Yes. I’m in manual. The manual aperture control works fine. But I only have 30,45, 60, 90,125, etc. as my shutter choices. Cannot for the life of me find multiples of 25 that we PAL people like.
    Cheers.
    V.L.
  • Stefan Narancic
    May 4, 2010 at 4:58 pm
    hello vladimir
    in menu
    go to second last icon (advance options)
    choose exposure
    under exposure level increments
    there i suspect your camera is set to 1/2
    it should be 1/3 to access those 50… 100 steps for the 180 rule
    1/3 is also the default setting (euro 7d)
  • Damienne Caron
    May 5, 2010 at 10:12 am
    Hi Vladimir,
    If you get a useful answer to your question please share it. I am forced to shoot at shutter speed 100 when in 720p (PAL).
    Damienne
  • Vladimir Lozinski
    May 5, 2010 at 2:42 pm
    Hi.
    Sorry for not tracking my own posting. I have been in Bangladesh shooting for the past 3/4 weeks.
    The problem seems to have been a software glitch.
    I finally reloaded the firmware and all came back to normal. 50/100/ etc frame shutter rates popped up as per normal. I have been trying to recreate the fault but unsuccessful. I think it was when I pushed some of the latitude parameters that it went strange on me.
    The only advice I can give from the experience is to reload the firmware and hope.
    Regards.
    VL
  • Vladimir Lozinski
    May 5, 2010 at 2:46 pm
    P.S. Stefan’s answer cracked it. Brilliant. Thanks for that.
  • Damienne Caron
    May 14, 2010 at 9:57 am
    Hi Vladimir,
    I followed your advice and uploaded the firmware (actually I upgraded to the newest firmware) and in 720 50p mode I have only these shutter speeds: 60-80-100-etc
    Whereas in 1920 25i, I have 30-40-50-60-80-100-etc
    Do you have the same values?
    Damienne
