Activity Forums Adobe Premiere Pro Change Shift+Click to select multiple clips in the timeline to the more traditional Command+Click?
  • Change Shift+Click to select multiple clips in the timeline to the more traditional Command+Click?
    Posted by Jason Peterson on June 13, 2016 at 5:33 pm
    Is there a way to change this? I would be extremely grateful for the help.
    I use a Mac and in every single other program I have ever used on a Mac when you need to select more than one thing you hold down Command and select the next. For some reason in the Premiere timeline this is changed to Shift. I never remember this one thing until after I have accidentally done it the other way and I’m not even sure what happens when I try to select multiple clips by holding down Command, but it’s not what I want to happen.
    Jason Peterson replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
