Activity Forums Adobe After Effects Expressions Change Shape Layer Color Based on Source Text Value
  • Change Shape Layer Color Based on Source Text Value
    Posted by Adam Haas on August 14, 2018 at 5:36 pm
    I have a text layer that shows “Good” or “Bad” based on another layer.
    I have a shape layer that is behind that text, and I want the color to change to red if the text says “Bad” and green if the text says “Good”.
    I thought this would be pretty simple, but an if statement on the color attribute of the shape layer doesn’t seem to be working.
    Adam Haas replied 8 years, 1 month ago 2 Members · 4 Replies
  • Dan Ebberts
    August 14, 2018 at 5:51 pm
    Something like this, probably:
    txt = thisComp.layer("text").text.sourceText;
    if (txt == "Good")
    [0,1,0,1]
    else if (txt == "Bad")
    [1,0,0,1]
    else
    value
    Dan
  • Adam Haas
    August 14, 2018 at 5:58 pm
    Well, it’s kind of working. I see the colors change, however when I try to set to a specific color, it just ignores it:
    if (txt == "Good")
    [121,193,143,1]
    [189,80,80,1]
    else
    value
  • Dan Ebberts
    August 14, 2018 at 6:00 pm
    The colors have to be normalized (between 0 and 1):
    if (txt == "Good")
    [121,193,143,255]/255
    [189,80,80,255]/255
    else
    value
    Dan
  • Adam Haas
    August 14, 2018 at 6:05 pm
    That did the trick! Thank you so much.
