Activity Forums Apple Final Cut Pro Legacy Change settings for logged clips?
  • Change settings for logged clips?
    Posted by Jason Connolly on February 29, 2008 at 4:47 pm
    Hello-
    I’ve just logged a ton of footage but have just now realized that I’ve logged all of my clips with 16 tracks of audio, when I only need 2. This a problem because if I capture with 16 tracks of audio, my capture will stutter and drop frames.
    How do I change the audio settings of logged, un-digitized clips in my bin?
    Jason
    MacPro, FCP 6.0.2, OSX 10.4.11
    Chris Borjis replied 18 years, 6 months ago 2 Members · 3 Replies
  • Chris Borjis
    February 29, 2008 at 4:57 pm
    select them all, and in one of the menu’s in fcp there is a “clip settings” option.
  • Jason Connolly
    February 29, 2008 at 5:06 pm
    Thanks, Chris – I tried that but FCP tells me my clips don’t “fit that description”
    Anyway, what I did was:
    1) Change my capture settings to what I wanted (1V, 2A)
    2) Select the bin I want to capture
    3) Right click, select “Batch Capture”
    4) In Batch Capture Window, UN-check the box for “Use logged clip settings”
    5) FCP will then capture at whatever your current settings are
    Jason
  • Chris Borjis
    February 29, 2008 at 6:47 pm
    weird, I’ve never had that happen when changing
    batch settings of logged clips.
