Activity Forums Apple Final Cut Pro Legacy Change Sequence Settings
  • Change Sequence Settings
    Posted by Robert Clegg on July 7, 2006 at 11:20 am
    Help please somebody.
    We have an edit that is being done here: Footage captured in 16:9 (Anamorophic).
    The edit has been created in a sequence which didn’t have the anamorphic tab clicked so all the footage in the sequence is now letterboxed.
    The only way I know to fix this currently is to go into every clip in the sequnce and manually click through the distort tab and change the Aspect Ration to “0” from 33.3. There are hundeds of clips in the sequence so this going to be untenable… is there any easy quick way of doing this!! Please help!!
    Cheers
    Rob
    Robert Clegg replied 20 years, 2 months ago 3 Members · 3 Replies
  • Felix Bueno
    July 7, 2006 at 12:04 pm
    Hi Rob
    Just right-click or ctrl-click a clip with the correct settings and press “copy”. Then select all the other clips, right-click any selected clip and press “paste atributes”, select “distort” and this should work.
    You can do it by right-clicking one of the selected clips in your timeline and pressing “remove attributes” too.
    Hope it helps!
    Felix
  • David Roth weiss
    July 7, 2006 at 12:05 pm
    Rob,
    Fix one clip and then copy that clip. Now select all clips after that clip and paste attributes, choosing distort from the menu that appears.
    DRW
  • Robert Clegg
    July 7, 2006 at 2:14 pm
    Brilliant thanks for the help – easy when you know how 🙂
