Activity Forums Adobe After Effects Expressions Change selected master properties with ExtendScript
  • Change selected master properties with ExtendScript
    Posted by Clara Martin on May 2, 2024 at 1:58 pm
    Hello,
    I would like to know how to change the text of a master properties which is selected:
    – I select the master property
    – I click on a button (that’s it)
    – this changes the text
    thanks in advance
    Clara Martin replied 2 years, 4 months ago 3 Members · 4 Replies
  • Hector Vera
    May 2, 2024 at 3:57 pm
    Incase you wish to know more on Master Properties in Master effect, here is a tutorial that I found: https://www.youtube.com/watch?v=H1ZsiQy764Q
    First you select the layer of the Master Properties to change, then click on the Master Properties Icon and then select the Master Properties you wish to change by scrolling down. Then you double click it and type in that new text.
    You should see the updated text in that Master property layer afterwards.
  • Clara Martin
    May 2, 2024 at 8:15 pm
    Thank you for your replay.
    Unfortunetely i know it, i want to do it with script. Is it possible ?
    Thank you in advance 🙂
  • David Conklin
    May 2, 2024 at 8:52 pm
    I think this is what you’re asking for. Let me know if not.
    This script will update your [first] selected property on your [first] selected layer in your active comp to say “abcd.”
    (function(){
    app.beginUndoGroup("Updated selected text essential property.");
    var comp = app.project.activeItem;
    var lyr = comp.selectedLayers[0];
    var prop = lyr.selectedProperties[0];
    prop.setValue("abcd")
    app.endUndoGroup();
    If you wanted to be more specific you could say
    var prop = lyr.essentialProperty.property(1);
    or
    var prop = lyr.essentialProperty.property("thePropertyName");
    Hope that helps.
  • Clara Martin
    May 3, 2024 at 8:10 am
    Thank you very much, this is exactly what I wanted 🙂
