Activity Forums Adobe After Effects Change SD 601 color space to 709 for HD?
  • Change SD 601 color space to 709 for HD?
    Posted by Ninetto Makavejev on August 11, 2010 at 8:58 am
    Hello,
    Todd Kopriva steered me over to this forum from the PremPro forum, maybe someone has a good tip/workflow how I can convert uncompressed SD material, which has already been color corrected/mastered to the 709 color space that the HD project requires, using the SD Material as source.
    thanks in advance, Ninetto
    Ninetto Makavejev replied 16 years ago 2 Members · 5 Replies
  • Walter Soyka
    August 11, 2010 at 1:38 pm
    Check out Color management and color profiles.
    In AE, start a new project. In Project Settings, set the working space to HD (Rec 709). Import your footage, put it in a new comp, then make sure Interpret footage > Color management > profile is set to SDTV. (Avoid NTSC 1953.)
    Walter Soyka
  • Ninetto Makavejev
    August 12, 2010 at 11:03 am
    Thanks for the tip, it almost sounds too easy.
    The material delivered to me is (supposedly) uncompressed AVIs in Adobe-RGB space.
    So am I right in assuming that setting up the comp as 709 will interpret this material correctly when I export final comp as Blu-ray m2t files?
  • Ninetto Makavejev
    August 12, 2010 at 9:14 pm
    Appreciate the thoughts…
    This project is for an artist who demanded Blu-ray files to be looped on a Media Player in a gallery.
    So, yeah… that’s what the client wants, Blu-ray. He did not specify whether he meant Blu-ray H.264 /mp4 or Blu-ray /m2v… but my experience in the art world is the equipment in these places vary wildly, there is almost never anyone with any technical capabilities, and I figured if the gallery has a lower-end media server, it would have an easier time with the m2v files rather than mp4 format.
    I have not experimented extensively with Blu-ray files, would there be any reason at all to prefer the H.264 format?
  • Walter Soyka
    August 12, 2010 at 9:40 pm
    [ninetto makavejev] “I have not experimented extensively with Blu-ray files, would there be any reason at all to prefer the H.264 format?”
    Yes — it looks about the same as MPEG2 at half the bitrate.
    Walter Soyka
  • Ninetto Makavejev
    August 12, 2010 at 10:27 pm
    We are getting slightly off the track here, but funny you quote your wise words, Dave… because since I read them at a different post I decided not to compress output from AE… where my initial suspicions were aroused when I saw the render cue does not offer the same presets for Blu-ray as in Premiere.
    But now comes the double-whammy case scenario. In Premiere I simple imported the AE-Comp via dynamic link and will compress output via AME from Premiere: I assume this fulfills your advice NOT to compress from AE? I guess AE would just be acting like a frame server pushing uncompressed frames into Premiere via DynLink, right?
