Activity Forums Adobe After Effects Change Render Settings in a Script
  • Change Render Settings in a Script
    Posted by Geoff Rights on August 11, 2016 at 8:46 pm
    Hey All,
    I was able to create an item for the render queue using this syntax:
    var renderItem = currentProject.renderQueue.items.add(currentComp);
    How do I access the render settings of that render item and change the resolution output of the render to a third? I haven’t had any of these work:
    renderItem.resolutionFactor = [.33,.33];
    renderItem.renderSettings[1].resolutionFactor = [.33, .33];
    renderItem.renderSettings.resolutionFactor = [.33,.33];
    Thanks for any help.
    Walter Soyka replied 10 years, 1 month ago 2 Members · 3 Replies
