Activity › Forums › Adobe After Effects › change render log dialog default
  • change render log dialog default
    Posted by Matt Stalker on September 7, 2010 at 2:19 pm
    Is it possible to make a modification to set the render log dialog in the render queue to default to a different setting (plus per frame info)? It doesn’t seem to be part of the render settings or output module…
    I, uh, always forget to do it manually…
    Matt
    Matt Stalker
    Center City Film & Video
    mstalker@ccfv.com
    Matt Stalker replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
