Activity › Forums › Adobe After Effects Expressions › Change rate of movement between two points
Posted by Mike Foran on October 10, 2024 at 7:33 pmSorry if this has been asked before in some form but I can’t find an answer. I’m looking to dynamically determine and set variables for the beginning and end position of an object, and then use an expression to move that object at a rate I determine. So p1=[x1,y1], and p2=[x2,y2] and then I would like to move the object in a line between those two points at a certain rate. Thanks.
Brie Clayton replied 1 year, 11 months ago 3 Members · 8 Replies -
Dan Ebberts
October 10, 2024 at 7:50 pmThis is a pretty general solution that should work OK. You can tie variable spd to a slider (as long as you don’t animate the slider):
p1 = [100,100];
p2 = [500,500];
spd = 100; // pixels per second
tStart = inPoint;
v = normalize(p2 - p1);
t = Math.max(time-tStart,0);
d = Math.min(spd*t, length(p1,p2));
p1 + v*d; -
Mike Foran
October 10, 2024 at 9:47 pmSomehow I knew you’d have a solution to this one Dan. Works a charm! Many thanks!
Mike Foran
October 11, 2024 at 4:43 amWoah it’s been a while since I’ve posted a question in here. Are these coins a way of paying folks who volunteer solutions?
Mike Foran
October 11, 2024 at 2:35 pmDan, I always enjoy breaking down your solutions because I learn something new every time. What I’d like to do here that I can’t seem to figure is to make this movement loop. I’m thinking that it would be modifying the tStart variable so that, instead if being set to inPoint, it would instead be reset at certain time increments. I’m just not sure how to get there. Ideally, the loop would reset on the frame BEFORE it reached the position in P2 (the shape being moved in this case has repeaters to form a grid, so I’m trying to seamlessly move this grid from one instance to the next on a loop, so it seems like it is endlessly moving). I’d appreciate your guidance.
Dan Ebberts
October 11, 2024 at 3:54 pmIf it needs to loop, I think I’d approach it a little differently:
p1 = [100,100];
p2 = [500,500];
tTot = length(p1,p2)/spd;
tStart = inPoint;
t = Math.max((time-tStart)%tTot,0);
linear(t,0,tTot,p1,p2) -
Mike Foran
October 11, 2024 at 4:34 pmAh interesting! Well that is working great as well. Thanks again for your invaluable assistance.
Brie Clayton
October 11, 2024 at 6:18 pmHello Mike,
Yes! COW coins reward the overall participation in Creative COW itself, forum coins and badges highlight a person’s niche knowledge, and solve coins underscore how very helpful folks like Dan Ebberts are.
Right now we are paying in recognition, but toward the end of this month we will be holding a raffle that links back to coinage in specific forums with RE:Vision Effects plug-ins!
