Activity › Forums › Apple Motion › Change projecr size
  • Change projecr size
    Posted by Max Frank on January 17, 2010 at 11:28 am
    Pls forgive me if this has been discussed before.
    I’ve got several text animations made in Motion 3 in PAL Anamorphic.
    However, the FCP project is now being edited in 1920×1080, and as a result, I now need to bring these animations in at 1920×1080.
    Question: How do I CHANGE my existing Motion 3 projects from SD Anamorphic to the 1920×1080.
    Thanks in advance,
    Wayne
    Max Frank replied 16 years, 8 months ago 2 Members · 2 Replies
  • Mark Spencer
    January 17, 2010 at 3:08 pm
    Create a new project with the proper settings, open your existing project, and then either copy-paste or drag all the layers from the original project to the new project.
    You’ll then need to manually resize layers to fit the new project size.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Max Frank
    January 18, 2010 at 9:57 am
    Mark,
    Thanks so much – that’s what I needed to know.
    Tx,
    W.
