Activity Forums VEGAS Pro Change preferences – Capture
  • Change preferences – Capture
    Posted by Naiche Lujan on October 14, 2008 at 5:40 pm
    I have been exclusively capturing DV footage, so when that dialog comes up and asks you if you want to capture HDV or DV, I choose DV, and after awhile I decided to mark the little checkbox that says not to ask me again.
    Well, of course, now I need to import some HDV, and cannot figure out where I can reset the preferences so that it asks me what type of import I want to do.
    Hopefully this is an easy fix.
    Naiche Lujan replied 17 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Terry Esslinger
    October 14, 2008 at 6:09 pm
    The little box that you are missing states “This method can be cahnged later in the Preferences” but I looked and I can’t find it. I know this has been asked before and answered.
  • Naiche Lujan
    October 14, 2008 at 6:13 pm
    Yeah, I thought I had read that message, but i couldn’t find it either. I tried searching a couple different ways, and couldn’t find an answer, I’ll keep looking. Thanks for the confirmation.
  • Naiche Lujan
    October 14, 2008 at 6:22 pm
    I even selected the “Default All” option in the preferences, but that did not work.
  • Edward Troxel
    October 15, 2008 at 12:09 am
    Go into VEGAS. Now Options – Preferences – Video tab
    Check or uncheck the “Use external video capture application” box.
    Edward Troxel
    JETDV Scripts
  • Terry Esslinger
    October 15, 2008 at 4:21 pm
    Yes, this will change the video capture app that opens when you open ‘capture’. However it will not bring back the choice window that you originally would see. By removing that window (Always use this choice!) it would seem that you have relagated yourself to the additional clicking necessary to do as Edward has stated. Not really a big deal but I wish I would not have eliminated the window in the first place.
  • Edward Troxel
    October 15, 2008 at 8:55 pm
    You *CAN* get the question box back. Just hold down CTRL-SHIFT when starting Vegas and it will start asking that question again. Of course you’ll need to go back and change all the preferences you’ve changed again.
    Edward Troxel
    JETDV Scripts
  • Naiche Lujan
    October 20, 2008 at 11:32 pm
    CTRL+SHFT worked!
    Thank you so much Edward.
    Now I will not check the box again. It was slightly misleading for them to tell you that you could get that box back in the preferences.
    Anyway, I can reset my prefs again. Not a huge deal
    Naiche
