Change precomp duration and inPoint of following precomps
I’m trying to build a script that changes the duration of a precomp and any layers inside it from 1 second to x seconds as an example, while also moving the inPoint of any following precomps or layers so that they don’t overlap.
Attached are two photos of what I want to achieve. I want to change the duration of precomp “Two” from 1 second to 2 seconds and move precomp “Three” to start from the 3rd second instead of the 2nd so they don’t overlap.
I tried changing the inPoint and outPoint of the precomp, but it doesn’t seem to change. Any help or guidance is greatly appreciated.
