Activity Forums Adobe After Effects Expressions Change position every 3rd frame
  • Change position every 3rd frame
    Posted by Y. Bar on April 21, 2010 at 12:05 pm
    Hello,
    I have a layer which I animate between 2 position keyframes.
    I would like this layer to move from one position key to the next, by changing its position not every frame, but once every 3 frames.
    How can I achieve this?
    Yaron.
    Dan Ebberts replied 16 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • Lloyd Alvarez
    April 21, 2010 at 12:24 pm
    frameInterval = 3;
    fps= 1.0 / thisComp.frameDuration;
    posterizeTime(fps/frameInterval);
    value;
    Lloyd
    https://aescripts.com
  • Y. Bar
    April 21, 2010 at 7:15 pm
    I don’t understand how to use this expression.
    I need to keep the position between the 2 keyframes I set already, only to make the transition between them occur instead of every single frame – every 3rd frame.
    By the way, is there a way to populate the entire timeline between 2 keyframes with keyframes automatically ? (instead of scrolling forward every frame and adding a keyframe)
    At least a way to set a shortcut to ‘Add Keyframe’ ?
    Thanks.. Yaron.
  • Lloyd Alvarez
    April 21, 2010 at 7:27 pm
    You need to apply that expression to the position property. Alt-click on the timewatch icon for position and copy and paste the expression into the text field that opens.
    The shortcut to add a keyframe for position is Alt-P
    -Lloyd
  • Dan Ebberts
    April 21, 2010 at 8:35 pm
    As I recall, posterizeTime() can be a little temperamental in CS4, so if you can’t get it to work, you could try it this way:
    t = framesToTime(Math.floor(timeToFrames()/3)*3);
    valueAtTime(t)
    For creating keyframes at every frame, you can create the default expression (Alt+click the stopwatch) then use Animation>Keyframe Assistant>Convert Expression to Keyframes. Then you may want to delete the keyframes before and after your span of interest.
    Dan
  • Lloyd Alvarez
    April 21, 2010 at 9:01 pm
    Hey Dan,
    What do you mean by temperamental? I’ve never had any issues with posterizeTime.
    -Lloyd
  • Dan Ebberts
    April 21, 2010 at 9:16 pm
    Mostly it doesn’t work. I just tried this on a keyframed solid’s position in a 30fps comp:
    posterizeTime(10);
    value;
    It doesn’t have any effect. This is only CS4 I’m talking about.
    Dan
  • Lloyd Alvarez
    April 21, 2010 at 10:02 pm
    Wow! you are right, when I tested the expression i posted in this thread I did it in CS5 and it worked fine but when I just tried it in CS4 it doesn’t work. I can’t believe I didn’t know about this, thanks for pointing it out. I am assuming that since it is fixed in CS5 it was a known bug.
  • Dan Ebberts
    April 21, 2010 at 10:12 pm
    Yeah, somebody here ran into it last year some time. I reported it in case no one else had.
    Dan
