Activity Forums Adobe After Effects Change orientation of corner pin in mocha
  • Change orientation of corner pin in mocha
    Posted by Nick Shaw on June 2, 2012 at 6:59 pm
    So i did a track in mocha with adjustments and all that and when I import the tracking data to after effects to an image I want to add to a tablet the corner pin is translating the horizontal as vertical and the vertical as horizontal. Is there a quick way to fix this (like rotate all the corner pins to the left) or something? Let me know if this makes sense or not.
    Dan Fredley replied 14 years, 2 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    June 2, 2012 at 8:53 pm
    Ideally, you’d go back into mocha and re-apply the Surface. If you want to mess about in AE, then apply the Distort>Transform effect, place it on top of the corner-pin and make your transform operations from there.
    This may or may not work – it all depends where you’re at and where you want to end.
    If you’re comfortable with pick-whipping to create Expressions, then simply pick-ship the four corner-pin points to re-align the orientation of your image.
    You could also precomp the insert layer and set it assbackupwards. 😉
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Dan Fredley
    June 21, 2012 at 8:09 pm
    Use the rotation option on this script:
    https://aescripts.com/cornerpinner/
