Activity Forums Adobe After Effects Change opacity over time with a fade not flicker
  • Change opacity over time with a fade not flicker
    Posted by Ian Ellerby on August 2, 2015 at 10:34 am
    Hi
    i’m trying to change opacity of layer over time, going from 100% to 50% in a 1 second fade, hold for 10 seconds at 50% opacity, then return to 100% over 1 second, hold at 100% for 10 seconds, and repeat and repeat etc
    I can see lots of expressions with a flicker type approach, can’t find on posts an opacity expression with a fade.
    Thanks if anyone can help.
    Ian
    Ian Ellerby replied 10 years, 9 months ago 2 Members · 2 Replies
  • John Cuevas
    August 3, 2015 at 1:04 pm
    You could do this with a LoopOut Expression. Create the 1 second fade to 50, 10 second hold, then fade back to 100 and a 10 second hold. Then add the following expression to opacity:
    loopOut("cycle")
    Here’s an example project: 9107_loopout.aep.zip
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ian Ellerby
    August 3, 2015 at 1:27 pm
    Hi Johnny
    That’s brilliant, a great solution, thanks very much for helping, do appreciate it.
    Ian
