Activity Forums Adobe After Effects Expressions Change opacity at a layer marker
  • Change opacity at a layer marker
    Posted by Chris Huggett on March 23, 2007 at 8:38 am
    Hi guys
    I am trying to recreate in 6.5, the opacity flash aexpression found in version 7s presets. Im having difficulty with it, and although the script does not throw up any errors, it still won’t change the opacity at my markers.
    I have applied the espression slider to a layer and also the solid composite effect. To this i have applied the expression
    try{
    flashWidth = effect(“Opacity Flash – layer markers”)(“Flash Width (msec)”) / 2000;
    timeToMarker = Math.abs(time – marker.nearestKey(time).time);
    easeOut(timeToMarker, flashWidth, 0, 100, 0)
    }catch(err1){
    100
    And i have also adjusted the effect parameters so that it is on Add mode.
    No luck… and ideas as to why.
    Thanks alot
    Chris
    Chris Huggett replied 19 years, 6 months ago 1 Member · 1 Reply
  • Chris Huggett
    March 23, 2007 at 9:41 am
    Don’t worry guys, i worked it out.
    Cheers
    c.
