Activity › Forums › Adobe Premiere Pro › Change of titles
Change of titles
Posted by Dan Plonsker on September 14, 2006 at 11:36 amHi all,
Is there a way to change the fonts’ color of titles in one action (PP1.5)
and not going one by one (Copy/Paste of properties doesn’t work)?
I have to change 285 subtitles and I’m pulling my hair out….
well, whatever is left of it….
ThanksDan Plonsker replied 20 years ago 3 Members · 6 Replies -
Mike Velte
September 14, 2006 at 11:55 amNo, but you can create a new “Style” in the titler with all the properties of your new colored font and open each title, select the text and click the New Style you created to change color.
Dan Plonsker
September 14, 2006 at 12:18 pmThanks Mike,
I’m using ColorCop for the new color and with the color picker at the titler window I select the text and sample it. Your way is another good idea but I still needs to go one title at a time so there is really no speeding of the process.Dan
Steven L. gotz
September 14, 2006 at 12:33 pmI don’t know your level of comfort with trying something like this, but here it is anyway….
The color is kept in the project file (in Premiere Pro 2.0) or the PRTL file in earlier releases. A simple text program designed to find and replace could change all of the colors in one pass.
Just use a copy of the project to do this. If you can’t find the location of the color, change one using the copy of the project and then compare the two text files with a text editor (MS Word will do the job).
I have a program I like for that, but I am away from my editing PC at the moment and can’t remember the name of the app.
Steven
https://www.stevengotz.com -
Dan Plonsker
September 14, 2006 at 12:40 pmThanks Steven,
That’s a really interseting way to do it.
I will try it.
Dan -
Steven L. gotz
September 15, 2006 at 6:32 pmI use this for $29.99
https://www.abacre.com/afr/index.htm
As I recall, I used it and when the free trial ran out, I had to buy it because it just made things too easy. Especially for changing multiple pages of my web site all in one go.
Steven
