Activity › Forums › Adobe Premiere Pro › change of lighting in video
  • change of lighting in video
    Posted by Carlos Vee on June 5, 2018 at 5:23 pm
    Hi. Not sure if this is a premiere or nikon topic but please refer to this: https://www.screencast.com/t/dZwEnmb3SZ
    Do you notice how the lighting gets brighter and brighter as the shot progresses? I know this has to do with the angle of the light but is there any way to avoid/prevent this or set myself better for this?
    Carlos
    Carlos Vee replied 8 years, 2 months ago 2 Members · 3 Replies
  • Jeff Pulera
    June 5, 2018 at 5:41 pm
    Hi Carlos,
    You must set Exposure (Iris), Gain, Shutter speeds to MANUAL on the camera, which apparently was on AUTO for that scene. What is happening at start of shot is the bright window is prominent in the frame, so camera compensates and makes overall image darker, then as you pan away from bright window and darker room fills more of frame, camera wants to then expose for that scene and opens things up to let more light into camera.
    Manually set exposure for darker part of room before you record, then as you move away from bright window, the rest of the room will be properly exposed without image brightness changing as it did.
    Jeff Pulera
    Safe Harbor Computers
  • Jeff Pulera
    June 5, 2018 at 5:44 pm
    Also, if you can’t re-shoot and need to fix clip in Premiere, apply color correction and then use KEYFRAMES to alter the color correction over time to hide the dramatic lighting change. I’ve had to do that before myself! In other words, make image brighter at start, then ramp down that brightness correction to “no change” as panned video moves towards proper exposure.
    Jeff Pulera
  • Carlos Vee
    July 14, 2018 at 6:38 pm
    Thanks Jeff! I’ll give this a shot next time!
