Activity Forums Maxon Cinema 4D Change object’s starting point in solver
  • Change object’s starting point in solver
    Posted by Joey Ciccoline on August 27, 2008 at 9:48 pm
    I’ve created an object that fall on another object using gravity and a solver. Everything works great, however, I want to have the object that falls drop from a greater height. When I try and move the object nothing happens. I can pull the object out of the solver and move it, but then when I put it back in, it’s position returns to where it was before I pulled it out of the solver. How do I change an object’s position once it’s in the solver object?
    Brian Jones replied 18 years ago 2 Members · 1 Reply
  • Brian Jones
    August 28, 2008 at 12:09 am
    turn off the solver, move the object, choose Initialize Object (or Initialize All Objects) from the Dynamics menu, turn the solver back on
