Activity › Forums › Apple Final Cut Pro Legacy › Change multiple Text settings one time ?
Posted by Pierre-luc Pare on May 18, 2006 at 9:37 pmI mean, I’m doing subtitles in FCP using Outline Text generator. is there a way to edit its settings and apply to all texts or I have to do it one by one ?
Thanks !
Don’t fear the tiger, the Cow is near!
Pierre-luc Pare replied 20 years, 4 months ago 5 Members · 5 Replies -
Arnie Schlissel
May 18, 2006 at 9:58 pmSorry, has to be done 1 at a time. You might want to look into buying either Traffic at https://www.xmedit.com/, or STLedit at https://www.stledit.com/
Arnie
https://www.arniepix.com -
Kevin Monahan
May 18, 2006 at 10:13 pmActually, Motion with the additon of AutoMotion would be my choice for handling a show wide change like that.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com -
Peter Wiggins
May 18, 2006 at 10:24 pmUse Martins subtitle generator, it is a lot easier and it is only $10 😉
https://www.digital-heaven.co.uk/fcplugins/dh_subtitle.php
Peter
Martin Baker
May 18, 2006 at 10:37 pmYou can do batch style changes to FCP text generators (including our DH_Subtitle plug-in) with TitleExchangePro from Spherico. It’s a little bit complicated but you basically export an XML with your current subtitles, then define a style template for TitleExchangePro and merge the two together to apply a new style across all the subtitles.
Martin
Digital Heaven, London UK
________________________________________
AutoMotion – 0-60 graphics in 5.2 seconds – Now Shipping
