Activity Forums Apple Motion change motion project frame rate?
  • change motion project frame rate?
    Posted by Marck Savoie voyer on February 26, 2008 at 7:54 pm
    Hi there!
    I’ve created some text animation in motion in 23.98 because that was what I was asked for at the beginning… Then I was asked to give the animations in 29.97 for 1080i delivery of the project.
    I believe I can’t change the frame rate of my Motion project once it was started… But is there a way of doing a copy paste of my project and paste it in a new project with the correct frame rate? Or will I have to start from scratch?
    Marck
    Nayeli Garci-crespo replied 10 years, 1 month ago 10 Members · 11 Replies
  • 11 Replies
  • Arnie Schlissel
    February 27, 2008 at 7:19 pm
    You can certainly copy & paste from one project to another. You’ll probably have to adjust some of the keyframes for timing, though.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Marck Savoie voyer
    February 28, 2008 at 3:39 am
    I actually tried to create a new project and copy paste between the 2 and it did’nt work… When I hit paste, nothing happens… But if I paste in the same project, it works 🙁
    Any thoughts?
  • Glenn Sakatch
    February 28, 2008 at 4:58 pm
    I just created (using a template setting) a 1080i 60 project. Added some footage, and built a quick lower third using a generator, a rectangular mask, blur filter and colorize filter. I then added some text, and added a cheesy behavour to it.
    I then created a new project, custom setting, 1080…23.98. Moved it to my other screen.
    Went back to first project, copied all my groups, went to my 23.98 project, hit paste, and everything came in…all footage, filters and behaviours.
    Using Motion 3.02
  • Isazaly Mohd isa
    October 28, 2010 at 5:13 am
    You can OPEN your Motion project with TextEdit, search for 30 and change the value there and save it. When you open the project in Motion, you will get the NEW framerate settings.
    Hope that’ll help you or anyone who needs it.
    Isazaly Mohd Isa @ Zalee
    Apple Certified Trainer
    Malaysia
    https://isazaly.blogspot.com
  • Federico Betta
    November 3, 2011 at 2:53 pm
    THANKS!
    federico
  • Tony Brittan
    January 19, 2012 at 4:05 pm
    That was a great tip! I had a project that I didn’t create and needed to change the framerate without having to re-create the whole project…this worked perfectly! I did have to change a couple of properties, such as the font size, but other than that, it was perfect.
    Tony Brittan
    Island Shore Productions!
  • Stephen Smith
    January 20, 2012 at 4:34 pm
    Motion VFX just released a Free plug-in that changes your Motion project’s FPS within a click. Check it out here: https://www.motionvfx.com/mtools-2.html
    Unfortunately it only works with Motion 5. 🙁
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Balaji Muthappan
    March 18, 2012 at 2:49 pm
    cool!!! i saw lots of round abouts… in other forums… this is so simple and SUPER! thank you again!
  • Ryun Hovind
    February 7, 2014 at 10:52 pm
    That was an awesome tip. You have a new blog follower my friend.
    Ryun
    Just what is it that I don’t get?
  • Nayeli Garci-crespo
    May 12, 2016 at 2:11 pm
    THANKS for this tip. Amazing. I love that the project can be edited with text.
    FYI, in order to change a project from 59.94 to 23.98, I had to change “60” to “24”… first try I put in 23.98 and it showed up as 23.96. Not sure what you would put in if you wanted straight up 24 fps.
    I was also able to change the project preset from 720 to 1080 (and then of course had to resize in the project).
