Activity › Forums › Adobe After Effects › Change Mask Starting Point
  • Change Mask Starting Point
    Posted by Ryan Moyer on February 27, 2010 at 9:05 pm
    I am attempting to draw a path for 3d Stroke by using a mask within After Effects.
    I drew a path with the pen tool, thinking the path would begin at the start of the first point I drew. However, for some reason when I animate a stroke on that path, it starts at around the 3rd point that I drew, so when I start animating the stroke using the start/end commands it starts drawing it at the wrong spot.
    Is there a way to change the “starting” point of the mask?
    Adam Pyburn replied 14 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Johnson
    February 27, 2010 at 9:33 pm
    Select the mask vertex you want to be the starting point and select “make first vertex” from the dropdown menus at the top of the program window … I don’t recall off-hand which one its in, but it should be pretty easy to find.
  • Ryan Moyer
    February 27, 2010 at 9:36 pm
    Hmmm, for some reason “set first vertex” is grayed out.
  • Ryan Moyer
    February 27, 2010 at 9:44 pm
    It looks like it’s grayed out because I don’t just have one point selected, but how the heck do I select just one point? If I click on one it highlights the entire path.
  • Joey Foreman
    February 27, 2010 at 10:00 pm
  • David Johnson
    February 27, 2010 at 10:32 pm
    In the comp window, you should just need to click off the mask once to deselect it, then simply click the vertex you want to select … I’m still on CS3 so I hope Adobe hasn’t made such a simple thing more complicated in CS4.
  • Ryan Moyer
    February 27, 2010 at 11:16 pm
    For whatever reason, every time I was clicking on one vertex (even after deselecting them all) it was selecting everything. I just restarted the program and then I was able to pick one at a time.
    Odd.
  • Adam Pyburn
    March 21, 2012 at 2:25 pm
    wow, i had been trying some silly work around on my last project for exactly this issue. thanks for bringing this to light. i wonder why the first pen point isn’t set as the first vertex by default? seems like that would be a bit more intuitive.
    thanks again!
