Activity Forums Adobe After Effects Expressions Change linear animation to EasyIn in expression
  • Change linear animation to EasyIn in expression
    Posted by Gonzalo Tórtola on March 14, 2017 at 1:34 am
    So, here’s the problem: I want to change this LINEAR animation and turn it to EASY IN, but the problem is that I have linked keyframes 4 and 5 (SCALE: x axis) with a Slider.
    I WANNA CHANGE THAT LINEAR ANIMATION TO EASY IN . I DON’T KNOW IF THERE’S A WAY, BUT IF IT IS PLEASE HELP ME.
    This is the expression I’ve using and works perfect (thanks Dan Ebberts), but I wanna make the animation Easy In ->
    sVal = thisComp.layer("Control Panel").effect("Rectangle Scale [X]")("Slider");
    if (time < key(4).time)
    x = linear(time,key(3).time,key(4).time,key(3).value[0],sVal)
    else if (time < key(5).time)
    x = sVal
    else
    x = linear(time,key(5).time,key(5).time,sVal,key(6).value[0]);
    [x,value[1]]
    David Cabestany replied 9 years, 1 month ago 3 Members · 3 Replies
  • Dan Ebberts
    March 14, 2017 at 4:04 am
    I’m guessing you just need to change linear() to ease() or easeIn() or easeOut() depending on what you’re after exactly.
    Dan
  • Gonzalo Tórtola
    March 14, 2017 at 4:20 am
    Oh thanks so much!! My mistake was that I’ve been writing easyIn / easyOut not “ease”, so stupid! The animation is fine, but I want it to be like this curve… Is it possible?
    Looking for help… Looking for someone I can help!
  • David Cabestany
    August 10, 2017 at 3:36 pm
    I have the same issue, I need the blue curve to be like the pink curve, but easeIn gives an abrupt stop instead of an eased one like the keyframes, is there a function besides linear, ease, easeIn and easeOut that can achieve this?
