Activity Forums Adobe After Effects Change layer proportion in After Effects?
  • Change layer proportion in After Effects?
    Posted by Marine Houshou on September 9, 2022 at 1:19 pm
    Hey guys, I-I am trying to animate a layer, but it crops out in my composition when I move it because the proportion of the layer itself is not big enough, but how do I change that proportion specifically so I can move it without cropping out?
    You can see in the image below better, when I try to lower the Y position, it crops out, because the layer it’s in the edge, but i don’t know how to make the space to work bigger.
    If someone can help me out, please.
    Marine Houshou replied 4 years ago 2 Members · 2 Replies
  • Andy Kiernan
    September 9, 2022 at 2:42 pm
    if i understand right, press cmd+K to open comp settings and make the size of the comp bigger
  • Marine Houshou
    September 9, 2022 at 10:35 pm
    thanks for the answer! but i discovered what I specifically needed to do, I needed to make that layer itself in a composition for it, so then, I could normally change it`s proportions!
