Activity Forums Adobe After Effects Expressions Change Layer position by certain value by Marker?
  • Change Layer position by certain value by Marker?
    Posted by Robert Røbke on July 30, 2021 at 2:22 pm
    is there any expression to change a layer or precomps position with markers? I found something like this:
    https://www.youtube.com/watch?v=b9AVrj8UFvs
    https://www.youtube.com/watch?v=B_3XS2-VWOM
    But it’s not exactly what i am dreaming of and i am not able to change it like i want. ? I want a layer / comp to go up (y position) e.g. for 100px each time if i set a new marker.
    Hope you can follow along ? Looking forward to your answer. Thanks alot in advance! ❤
    Mischa BKHR replied 5 years, 1 month ago 4 Members · 4 Replies
  • David Cabestany
    July 30, 2021 at 4:17 pm
    Try this one, it will repeat whatever keyframed animation you have at the beginning of the layer each time a marker is passed, if you need it to offset the animation rather than just repeating it then someone will have to tweak it a little bit.
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time) n–;
    if (n > 0){
    valueAtTime(time-marker.key(n).time);
    }else{
    valueAtTime(0);
  • Robert Røbke
    August 3, 2021 at 7:25 am
    Hey thanks,
    this seems to be nearly the same as in the tutorial? I need the layer to go up in Y position for a certain number of pixels *each* time i create a marker.
    I guess there must be another solution, anybody?
  • Tomas Bumbulevičius
    August 4, 2021 at 8:00 am
    Hey Robert, some info is missing.
    1. Should it go up in time (animated) or just move by 100px instantly?
    2. Does it need to go down?
  • Mischa BKHR
    August 4, 2021 at 1:52 pm
    Hey Robert, just paste this in the position expression:
    P = transform.position; // layer position
    x = marker; // marker
    v = 100; // value that you want to move after each marker
    n = 0;
    if (x.numKeys > 0){
    n = x.nearestKey(time).index;
    if (x.key(n).time > time) n–;
    if (n > 0)
    d = x.key(n).index
    else
    d = 0;
    m = d*v ; //multiplys marker Index times value
    [P[0], P[1]+m]
