Activity › Forums › Adobe After Effects Expressions › Change layer color using text
  • Change layer color using text
    Posted by Asaf Lazarovich on April 26, 2018 at 2:58 pm
    Hi, so I need to change a layer’s color using the fill effect, but I need to get the color data as a text from a spreadsheet.
    I have Layer1 which is a text layer
    and Layer2 which I want it’s source text (for example: 1E29FF) to be used by Layer1’s fill effect to determine Layer1’s color
    is that possible?
    thank you!
    Dan Ebberts replied 3 years, 5 months ago 3 Members · 4 Replies
  • Dan Ebberts
    April 26, 2018 at 4:46 pm
    If Layer2 has the text for a hex number, I think something like this would work:
    txt = thisComp.layer(“Layer2”).text.sourceText;
    hex = parseInt(txt,16);
    r = hex >> 16;
    g = (hex & 0x00ff00) >> 8;
    b = hex & 0xff;
    [r/255,g/255,b/255,1]
    Dan
  • Asaf Lazarovich
    April 26, 2018 at 6:42 pm
    works perfectly, thanks so much Dan
  • Ian Ball
    April 11, 2023 at 2:09 pm
    Hello, I am trying to do this exact same thing but I cannot get it to work. I am pasting this code into the effects > fill > color property and my text layer is called “Layer2” – the error is “invalid or unexpected token” – Any advice greatly appreciated. Thanks!
  • Dan Ebberts
    April 11, 2023 at 3:42 pm
    This should be all you need:
    c = thisComp.layer("Layer2").text.sourceText.value;
    hexToRgb(c)
