Activity › Forums › Adobe After Effects › Change keyframes default TEMPORAL interpolation for easy ease?
  • Change keyframes default TEMPORAL interpolation for easy ease?
    Posted by Alexandre Marcati on October 26, 2016 at 1:34 pm
    I usually think the default easy ease is not easy enough.
    I like to change the keyframe influence (in the keyframe velocity window) from 33.33…% (default easy ease) to 80%. I think the motion looks smoother this way, most of the times.
    But I hate having to change it manually every time, so I wonder if there is a way to change the default easy ease settings so the keyframe velocity influence is set to 80% as default?
    Is there a way to change this setting?
    Michael Szalapski replied 9 years, 11 months ago 2 Members · 1 Reply
  • Michael Szalapski
    October 26, 2016 at 2:52 pm
    Not that I know of.
    There is a very handy tool out there that would enable you to make the interpolation you want with very little work though. Check out Flow on AE scripts. Really handy tool to have.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
