Activity Forums Adobe After Effects Expressions Change keyframe value using expression
  • Change keyframe value using expression
    Posted by Doni Donovan on March 12, 2019 at 2:26 am
    I found this script a couple month ago..
    Is there a chance to tweak it so i can change the value for all/both keyframes?
    keyNumToChange = 2; //change this - the key num to change(numbering starts at 1)
    newVal = [value[0],100]; //change this - the new size.
    target = transform.position;
    nearKey = target.nearestKey(time).index;
    lastKey =(target.key(nearKey).time>time) ?((nearKey>1) ? nearKey-1 : nearKey) : nearKey;
    nextKey =(lastKey
    Thanks for reply 🙂
    Doni Donovan replied 7 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
